I cant believe everyone is talking about paper templates...........
First off, try to centre tile layout around the toilet. Make sure that at the back of the toilet you have a joint in the centre - it is a nightmare to try and fit a whole tile behind a toilet.
Second, fit the full tiles around your toilet.
Third, mark a rough guide (very rough sketch to keep your mind straight about where to nibble) of the cut you need to make.
Fourth, lay the tile exactly in an adjacent line (either with adjacent horizontal; or vertical tile) and mark the point between edge of the set tile and toilet, on your tile to be cut, so that you have a starting point.
Fifth, get a marker rod/ruler (Rubi TS lateral stops are popular for this). Place it exactly up against the toilet base, and mark the position on your marker, of the mark made on the tile to be cut. Now use the rod as a template marker - keeping it exactly at 90 degrees to the tile, move it inch by inch around the toilet base. Mark on your tile, the point on your rod that was transfered from your tile - effectively you will quickly mark the shape of the cut exactly onto the tile.
Once the tile is marked up, use a wet cutter to cut out most of the waste tile, the use nibblers to get to the exact marked line. Until you get confident with your marking, always cut too little. As you cut more away you can place your tile against the toilet, and use a pencil to fully mark the final cut.
This really works well, is so much more professional than DIY or paper templates, and wont get you laughed off the first building site you work on.
However, If the tile is bigger than the gap between the toilet and adjacent wall, either partially cut away known waste on the tile until you can get a proper marking on it, or you may need to use a short ruler to mark a straight line adjacent to the toilet, or measure distance to toilet base at 1" intervals, then transfer to tile.
This may sound complicated at first, but I haven't time to photograph this in practice - sorry.
And to all you paper templaters.... bah humbug! :lol::lol::lol:
