The Beast
  • Thread starter Thread starter Mike ramsdale
  • Start date Start date
  • Featured
Just for balance - i confess to using my grinder on easily 9 out of 10 jobs. It's quicker.
(unless you've loads of rip cuts in limestone to make) 😛
Personally I go for the wetcutter 9 out of 10 times I just can't get a clean enough cut with a grinder I bought the festool one with the dust extractor port and had in my had I'd use that but it never comes out the box
I use a makita variable speed with marcrist akkumax blades and a very light hand. I can get a very clean cut on most tiles.
I find the trick is to run lightly down the glaze using a straight edge, then start to cut slightly past the first cut, this helps so the glaze pinging.
Well no body's really convinced me this is something I NEED to have, infact I'm convinced I really don't need one at all..
They're a nice tool to have and a must-have if you're fixing lots of stone. (in my opinion)
@Andystiletiling
Erm, I'm sure, yes yes you did , you borrowed my wet cutter the other week to cut slate skirts 😉
Or is it, "I don't need one, Craig has one" kinda thing 🙂🙂
You HAD to mention that didn't ya!! 🙂
Must admit it did give a nice exposed edge on the skirts..
Still for once in every blue moon, then yes mate...you have one 😉
Grinder for porc and ceramics.
Wet rubi for stone and envelope cuts in wet room.
There is no way you could cut Kathmandu slate from porcelanosa with grinder - just chips away no matter how careful u are.
The Beast
Tags Tags
None
Mike ramsdale,
Dumbo,
Mike ramsdale,
Dumbo,
