Tile Cutter Makes
Bluespot could be placed under others as it is up for 9.99 buy it now on EBAY. Im with Grumpy Montolit all the way so thats at least 2 votes. I do seem to remember this poll before with Rubi heading the list. How they manage that with those flexible tubular bars is beyound me but each to there own. :thumbsup:
All my rubis have solid stainless steel bars ..nothing tubular about them.....:lol:
Sorry Dave by tubular I did not mean hollow as that would be insane, but there is no denying that there is a greater deal more force able to be exerted on the solid central rectangular section used in a Montolit in comparison to the rubi set up.
Take structural steel work in a building for example. Columns are usually cylindrical due to the force exerted from either end. The round section equals the force exerted around the entire section making it less likley to fail. Load bearing steel running horizontally is a square section as it is stonger to with stand force bearind down on it along its length.
That is why I prefer the central spine of the montolit. :thumbsup:
Very true i suppose in the older models..but the new ones the ts+ series are alot stronger and the TX range have straight bars so even stronger......but i must say though i have a ts40 that is about 14 yrs old and not a hint of a bend in the bars and it has snapped lots of of quarry's over the years....use them and abuse them then they might break...use a cutter what is designed for then no probs.....:thumbsup:
True Dave each to there own. If we all liked the same things then we would all drive Ford's as long as they are Black. :thumbsup:
That's spot on tom....everybody gets used to a product and if they like it they stick with it.....You get that used to a make of cutter that it is second nature using it and you get to know the little tricks to get the best from it......:thumbsup:
I must admit I was first introduced to the Rubi and liked it. The main advantage that you could see the wheel to line up your cut. That was until I had to do a diamond set and then had difficulties until I used a Montolit which I found easier to use. Like you said Dave you then pick up your own ways of using your tools and now I don't have to see the wheel at all to judge my cut. Another advantage of the Rubi was to score a curved line such as for round a pedestal but I considered this too hit and miss to warrant choosing the Rubi over a Monti.
Like you said everyone likes certain attributes and these are mine. There is no reason that in the future I may want or need another cutter to do a particular job until then my monties serve me fine. :thumbsup:
There must be 5 or 6 points where the preasure is dealt with on a cutter and it isn't left dfown to the thickness of the bars that act as RUNNERS for the scoring mechanism and not something to put up with great preasure. It's all about engineering and Rubi have it clocked with their breaking mechanism - it's all about the point preasure.
Also, one single squared flat bar doesn't hold the scoring wheel which can be a mm wide perfectly when you're scoring a tough tile, it can wobble a bit (try wobbling your breaker / scoring mechanism) where as two bars can hold it firm, and actually the runner on the Rubi has 4 points where it's connected to those bars, where as a single bar cutter has one single large unit holding the lot usually which is why it wobbles.
Though I do like the cutters that have the moving breakers on them as you can snap the tile half way up the cutter and that's handy sometimes.
Each to their own as awlays hey? I still think Rubi should bring their prices down, and BAL for that matter - but maybe they know something I don't and that's why they're number one hey?
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
