L
LM
I think the vertical clamping of Genisis is better than the lateral action of other systems. It’s better imo because there’s no chance of a tile moving out of position while you clamp it, which is something you have to be careful with with others. As said also this means you don’t scratch any delicate surfaces. I like the versatility of the range of thickness that it can accommodate also.
In regards leaving clips in at the end of the day for the following morning and the clips sitting at a bad angle, simply leave a dry tile or two on the exposed side of the clip and the next day it’s not an issue.
You do make a good point about the quality of the product for its price. Tops do tend to wear out and need replaced after a while. I only have the manual pliers and they also wear out. That’s a problem they do need to sort out. That said RLS wedges can break too easily as well.
As I said I use the Block clips because of value, Genesis are too expensive for most jobs by comparison.
