Tile trim curving
A couple of thoughts spring to mind - As I think dave suggested if you're tiling a window for example is the trim sitting at 90 degrees to the tiles? If the tiles overlap the window opening its easy for the trim to sit at angle other than 90 degrees which would give you a gap.
Also if you are cutting the end off a 2.4m length of trim is the other end secure? If using small mitre block the trim will be waving around all over the place. A decent hack saw is def needed - No junior hacksaws with chrome!
I use a few different mitre boxes, I find if you cut small pieces of wood to hold trim tight in the box. Stops any movement. Hope this makes sense:thumbsup:
Trim=
