Tilers spirit levels??
after a quick charge and mess around the only negative(very slight) is it doesn't have a fine tune for vertical beam like my dw089k did. the positives are everything else!
to add to this it doesn't swivel super easily like the dw089k which makes fine adjustments easier
so do any of these level manufactures make them with the bubble you can adjust to get it spot on after it starts reading wrong? They used to
&& everything is online if you look hard enough I'm sure you'll find one!!
Pendulum on the laser we use so it gets it right every time 🙂
llevram,
Italy,
llevram,
Italy,
