Tilers spirit levels??
put beforehand,I like to explore. I do not want to teach anything to anyone, I just wanted to share the function of the receiver coupled to the laser, this is to avoid making 100 steps before starting work. It only takes 5 minutes to understand the squaring not only one room, but all the rooms to be laid.
excuse the drawings, but I just woke up from nap. 🙂
receiver with or without the function is the same.
with the receiver it is only faster and more accurate.
I posted the drawings, because I saw that no one use the receiver.
I always thought that the receiver, only served to the walls, in large distances, then one day I tried to put it on the floor, and surprise I saw that it worked, working alone, becomes very useful.
I've got the Bosh GTL3 for floors but found the line too feint. Also it's too low so if there is a hump in the floor the line stops there.
I used to have a PLS2 for walls but got that nicked.
So I bought one of these and it not only does the walls but also the floors, and the fine adjustment on the vertical is a god send.
As an Amazon Associate we earn from qualifying purchases.
I've got one of those , Put it on top of a tile if there's a bump on the floor
Not that anyone cares but I went for a set of empire e70 levels. Now I'm stuck with the problem of finding a decent carry case/bag. Anyone know of any that last more than 2 time opening and closing the zips !?
I'm sorry, I was not clear in the drawings.
you still have not figured out what good is the receiver ....;(
llevram,
Italy,
llevram,
Italy,
