Discuss Tiles de-bonding from new house in the Canada Tile Advice area at TilersForums.com.
Ajax123
1,213
Lincolnshire
[QUOTE="Anthony, post: 923819, member: 51465"]Sounds like calcium sulphide screed. A gypsum based adhesive required. Cement based adhesive reacts with it causing debonding. Also was the floor sanded? There’s a mineral that forms on top that needs to be sanded off. A lot of adhesive manufacturers say you can use cement based adhesive but needs to be primed twice diluted first. Neat for the second. But I’m not convinced. I use UltraTileFix csa[/QUOTE]
No it doesn't....
Tile Shop
Just out of interest, are there any of the Larsens Primer bottles knocking about or do you know exactly which one was used? Are we 100% sure it was acrylic? I'm just wondering if the smell may have been Acetic Acid/Acetone from a reaction with PVA and the adhesive?
If the Larsens PVA Bond was used as a primer, it could also explain the adhesive not bonding.
Reply to Tiles de-bonding from new house in the Canada Tile Advice area at TilersForums.com
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
5K
David John
  • Sticky
Hi, we run a small tiling company based in Wiltshire with most of our work on new build housing...
I am part-way through having retrofit underfloor heating installed (the panel type) and in a...
Ireland
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
