You want to check the batch numbers on them all. Seems odd to have one pack with only one tile out. Usually all made out about the same amount. If you've been working from several boxes at a time (as you are meant to) it could be one of the boxes are the ones with the dodgy side.
As above, check for an arrow or wording on the back, and use them all the same direction. And work the bigger ones in first so the grout joints are slightly wider on the others. Rather than the other way around which will screw you for space.
I'm thinking batch issue maybe. Check the boxes.
Also; what tiles are they where are they from? So people can avoid them lol
