Tiling around window
Backer are available to some description in most towns . Builders merchants carry them Wickes topps magnets the list goes on . Failing that plaster board . These are the easiest opens .
Plasterboard and plasterboard adhesive. Or double tile with off cuts and cement based adhesive...?
If you can get it one of the insulating tile backer boards (Wedi, Marmox etc.) would be my preference so that you do not get cold spots on the tiling causing condensation.
Check the set out of the tiling before fixing the sill because sometimes you may be able to adjust the sill height to match perfectly to a horizontal tiling joint.
