Discuss Tiling directly onto ply in the UK Tiling Forum area at TilersForums.com.
Its a bathroom pod, there is no cement being used just play screwed onto a steel chassis. I heard if you use marine ply it will be ok is that true? If not can i treat it with anything which will make it possible?
I am takign apart an old bathroom that has had thick sheets of ply screwed to joists and tiled....
JESUS these tiles are stuck on hard! takes me about an hour to remove one tile! I need to take tiles of to locate the screws so I can remove
backbreaking work!
suggests to me that ply is fine to tile on though....!?
Reply to Tiling directly onto ply in the UK Tiling Forum area at TilersForums.com
