Discuss Tiling on a painted plasterboard. HELP in the Canada Tile Advice area at TilersForums.com.
I was told the same many moons ago on a bal courseBAL technical told me in the past to apply a piece of high quality sellotape to the wall and rub on firmly, leave it for ten minutes and then remove it, if the tape pulls the paint off then you can't tile on it, if not then it should be fine providing you don't exceed the weight limits for plasterboard.
For eggshell and gloss. Not emulsion. Somewhere in bs5385 i seem to remember advice being to score 2mm x 2mm lines into the paint with Stanley knife, then apply tape. If it removes most of the paint (which invariably it will) don't tile direct, mechanically remove the paint.I was told the same many moons ago on a bal course
And keep your fingers crossed...If your using rapid set fexi ,prime and away you go ,sticks like hit
Reply to Tiling on a painted plasterboard. HELP in the Canada Tile Advice area at TilersForums.com
