Guest viewing limit reached
Tiling on to chipboard flooring
It was over-boarded with plywood - not a floating floor either as it was sat on joists. I did a very similar job for a police officer around 5 years ago. No blue sirens asking for a repair yet. I'd just pick an adhesive manufacturer, phone their technical helpline and follow their rules for prep/expansion joints etc. and mix everything in exact quantities. Then the ball is in their court if anything goes wrong.
sorry, yeh. I didn't mean floating floor.... I meant just a single skin chipboard on joists. Suppose i'l ring BAL technical line tomorrow and see what they advise...
The bath can afford to lose 6mm in height. I would lift the basin to tile under it and for the toilet and waste you don't need to consider a flexible pan connector. I would never use them anyway as waste matter can get caught in them. However you can easily buy offset pan connectors and that is what I would recommend you do. You need a good solid substrate to tile onto and lifting your sanitary ware is easier that repairing your floor. If your basin taps are on copper pipe only then I suggest you take it out and cut down the pipes and attach a flexible tap connector hose. Just remember to seal the olive with 4-6 wraps of ptfe to keep it from leaking as with all compression fittings.
ok... just looked into durabase/ditra matting.... surely this is the perfect solution? Or am i missing something?
Has anyone used this before and if so, would a layer of this on the chipbaord with fasflex adhesive do the job without adding any more height??
Fastflex should hold fine I would think to use ditra as ling as your floor has no bounce. What about backer board to 10mm?
As I said previously, i'm just trying to add as little height as possible at this stage. I have considered a 6mm hardi board but from what i can see, the ditra matting seems like a good solution!
Ok, thanks very much for all your help, it really is appreciated. I appear to have 2 options...
1. Prime the chipboard, buy BAL Fastflex adhesive and BAL super flexible grout. Tile directly onto the current chipboard floor and hopefully this would do the job, although no guarantee but it would not raise the floor any higher.
OR...
2. Prime the chipbaord, overboard with a 6mm tile backing board (hardiebacker or cement board), then buy BAL Fastflex adhesive and BAL super flexible grout. Again, no guarantee, but i'm getting close. One question with this method. Would the Fastflex adhesive be suitable with the hardi/cement backing board or would a cement based adhesive such as 'bal supercover rapid flex' be more suitable? I already have a 15kg bag of the rapid flex which I was prepared to discard if the fastflex would make a better job.
Rich
So am i right in thinking I have a 3rd feasible option?
3. Cover the chipboard flooring with Ditra/Dura Matting which would hopefully give me the flexibility and extra layer I need.
I've looked on the BAL product guide and it says that the 'Supercover rapid flex' is ok to use with uncoupling membrane, so.... I could use this adhesive to bed the matting onto the chipboard and then use it to secure the tiles to the matting???
Has anyone used this system before and would I still need to prime the chipboard before the matting goes down?
It is an option but, bear in mind that decoupling membranes are designed to help with lateral movement not vertical, so if your floor has any deflection, a membrane will not help solve this nor will it add any strength to the installation.
Just to throw something into the mix, quite a few rubber crumb (liquid and powder 2 part) manufacturers state that their products can go straight to green chipboard providing there's no deflection. Done quite a bit of site work where was 2PF was specced straight onto chipboard and there's never been a single failure with any of the floors. Personally I'd overboard it on a private job though.
Bal have a fibre based slc you can use on chipboard but you should still really be overlaying.
richardbell81,
sharpfamily,
richardbell81,
sharpfamily,
