Guest viewing limit reached
tiling onto tongue and groove?
Tiler Blackpool
hi guys,
ive been to measure a small job and the lady wantstiles just around her bath.(3.5 metres). the walls shes got at the mo are wooden tongue and groove with a satin painted finish. seems to be in good condition.........can i tile straight onto this?? with it being a satin / soft gloss finish and only 3.5 m2 i think itl be ok......any advice greatfully recieved!
Thanks in advance
tiler :grin:
thanks guys,my only problem with ripping off the t + groove is that it goes right behind the bath which means i would have to move the bath......which i cant do (my plumbing skills are non existant!) to be able to get it. would i just cut it off above the bath?
If you did it that way I would Silicon the the joint between the bath and plasterboard before setting any tiles just to double the seal or you could use bal wp1 tanking around the bath
Tags Tags
tiling usa
Tiler Blackpool,
White Room,
Tiler Blackpool,
White Room,
