Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
AliGage
Subscribed
4,531
1,188
Peterborough, England
I used 100mm concrete screws , just screwed it like a joist floor, just prayed to the good Lord that no mains gas/water pipes were hanging about ;)
That was why I didn't do it that way. Both mains were under it somewhere. It wasn't worth the risk especially with so many eyes on me.
But what I dud certainly worked!
My understanding is you either have insulation of some kind (like polystirene). Or thin air and a few support joists to raise the height above another substate (which chances are would be better to tile onto, as from what i've had customers tell me in the past is that its concrete). Ultimately though, the tongue and groove chipboad or ply they use to cover over isn't screwed down. Just loose laid with no fixings.
If i've got that wrong, please can someone correct me as this may be turning into a greyer area that i realised. As you can imagine, i don't get as much experience at this as some of you who go out and actually see it.
From what I've seen the chipboard is screwed to the joists but the joists are 'floating' on what normally is a layer of foam under each of them as the screed or slab is rarely flat enough to fix them down. The floor will appear flat and sound although will deflect to a good degree.
Suspended floor is timber joists set on top of stud, dwarf or supporting walls where generally the deflection is negligible
The first example you could lift the chipboard and fix and plug the joists to the concrete but then without packing the finished floor would be crazy undulating everywhere
AliGage
Subscribed
4,531
1,188
It's rare that I've ever found any joists in a floating floor
Wishiwasatoptiler
1,118
Northeast
So I'm in an independent tile showroom picking their brains on all things tiling and we touch on the subject of tile manufactures, so the info I'm told by the shop assistant is that the industry standard for tile size tolerances is 5%, meaning that one tile in a pack can be that much bigger than the one next to it in the same pack, even went as for as saying this is across the size range, so in that case they suggest a 600x600 tile could have a 5% increase across a pack. That can't be right can it.
Wishiwasatoptiler
1,118
Northeast
Even with limited knowledge I thought it was off as like you say that would be 30mm which would just be way off.
So +/- 3mm on any tile size??? Bri!
So with that in mind, when laying the tiles, it's just about splitting the differance across the last laid tile then, as I do unless you can get the shop to hand pick your tiles for you like matt...;-)
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
What else can you do? Lol
If you ever spot it just try and sway your customers away from that range or even that make. And make sure you report it to the manufacturer.
While its BS. They will want to know its happening and might not if QA is appauling. They could do with knowing as it might be a tiny adjustment to something in factory to correct it.
gamma38
1,058
Bedford
I was fitting some 300 x 300 absolute black for a customer around a year ago. It came from one of the online suppliers. It was shocking, up to 8mm difference. I called them up and asked them the tolerances. Eventually got an answer....... 5mm.... which is still shocking. I then proceeded to tell them the stuff i had was out of tolerance. The next reply was even worse. Oh yes that's the cheap stuff and it is sometimes a bit out of tolerance. After being put through to her manager and some harsh words, they agreed to resend me the same quantity out of the premium range. Tolerances for the premium...... 2mm.
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
