Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
jimthetiler
bring back flogging,thats what I say.Then well see how straight they get em.
Nice floor by the way.Reminds me of a job I took on once.The whole floor was dug up and put in bins and left in the blokes garden forever.All I was given was a photo copy of what it used to look like,he got jim the tilers version.
Rizzle from the Portizzle
Wanna hear another absolute stinker on this??? Based on the examples given in EN14411..... again.
Example.... A range of tiles which for examples sake is called Asbestos Bog.... available in 3 colours, Black, White and Poo Brown (3 colours associated with an asbestos bog... see what I did there? white pan, black cistern, and...... nevermind!)
The nominal size is 600x300. The customer has worked out a design for a single wall based on this advertised (and legally acceptable) size.
Due to the manufucturing process and timings of the batches, the Black is 599x299. The White is 595x296. The Poo Brown is 600x295.
These tiles are within nominal sizing.
These tiles are within tolerance because tolerance is only forced upon a single tile design from a single batch. Technically, all 3 tiles are different so the tolerance doesn't apply between them.
Tragically, these tiles conform to British and European Standards.
Bummer ay!
to cut manufucturing cost few factorys produce 600x300 tiles its cheaper to produce 600x600 then cut them
down and rectify depending on who is working that machine and time of day .how good the cutting is but dont worry BS has aloud for this .
With the increasing popularity of large format wall and floor tile we wish to remind you that the tolerances allow for a 0.5% warpage in tile planarity. therefore the European norms allow on a 60x60 tile 3.5mm tolerance between the centre of the tile and its corners.
This causes no problem whatsoever when the tiles are fixed in the normal draughtboard pattern, however, it can create problems if the tile is fixed brick bond or half bond particularly in the case of rectified tiles when the joint width is reduced to 1.5mm. It is advisable in this instance to ask your client to check for acceptability BEFORE fixing or alternatively to consider bonding 1/3 - 2/3 which will have the effect of halving discrepancies in planarity.
Hope this helps. this is generally the rule we use when selling anyway.
Amir Patwa
When you buy mechanically produced product there should be no tolerance! I run a service through " STONE GURU" and I travel to USA to inspect containers of natural and made made tiles of various sizes! If they are not uniform and calibrated
Then the whole shipment is rejected! Supplier carries the insurance
SJPurdy
Put a 2m long straight edge anywhere on the plasterboard and if there is any gap greater than 3mm between the straight edge and the board then it is not flat enough to tile.
On the tiled wall do the same test using a 2m straight edge with 3mm feet each end. If the gap between this and the tiles exceeds 6mm or the straight edge touches the tiling then the tiling does not meet BS.
This is based on my memory of reading BS5385 a while ago (I no longer have an up to date copy).
The same tests apply for the flatness of a floor substrate and floor tiling.
On a large floor the surface should also be flat within +/-15mm of the datum or as per the architects specified tolerance. I don't know the equivalent wall building tolerance.
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
