Wall and Floor Tiling Standards BS 5385 Part 1 and 2 British Standards, ISO Tile Fixing Standard.
Welcome to TilersForums.com, the place to discuss all tiling standards whether British Standards in Wall and Floor Tiling, BS5385, or ISO European Standards for Tile Fixing.
Tiling Standards
Wall and Floor Tiling Standards for the UK: British Standards in Tiling.
Discuss Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com.
Tile Shop
TTA/BSI vs Tilers:
Matt V
Devon
Read that in the TSJ and totally agree, 5mm joint in seamless work!
So who accepts responsibility?
Client?
Architect?
Interior designer?
And how does it get signed off?
I’am just a Tiler!
Down to Architect or Designer in my opinion to know what the standard is and apply it accordingly in the installation
Tile Shop
Nerd alert!!! INCOMING!
Based on the CoLTE of porcelain (4 in general) if a room is 20oC normally and the temp rises to 30oC when the bathroom, underfloor heating or whatever is in use, a 2400x1200 porcelain tile will expand to 2400.096 x 1200.048mm. Would that 0.096 x 0.048 of a millimetre make a difference? 1mm joints might struggle to buffer it, maybe.... but 2-3mm with flexi grout, flexi adhesive and appropriate expansion joints, shouldn't cause much of a problem but that also depends on their deformability.
Also need to bare in mind whether or not the substrate is subject to the same temperature fluctuations and how much they are likely to expand. for the same amount of plaster (2.4m) for example it will expand by 0.408mm.
IMO British standards are a little on the safe side, but not massively. I can see why they thought a need to amend. But the trouble is all the manufactures say their products are only guaranteed if used in line with the current standards. Ultimately if anything goes wrong, the tiler gets the blame, whether they were/weren't aware of the requirements or someone else requested it.
Tile Shop
that's for 6mm tile?
how much expansion when ufh is on 34 oC which is allowed on an area no bigger than 1m2 (under building regs, I believe)?
BS may not always be liked or look good on joint size but a good safety margin needs to be worked into the calculations
Thickness wouldn't make much of a difference, only to the time it takes to reach its top temperature. It would be on the assumption that the tile at the overall thickness would heat up evenly. I know thats not 100% realistic as one side would heat up quicker than the other, but the difference is neglegable and wouldn't alter the overall maximum possible expansion.
If you had a 1m room, with a single 1m slab, starting at 20oc rising to 34, gives a maximum expansion of 0.056mm. Still a very tiny and almost insignificant amount.
Even if it was divided into smaller porcelain tiles, the expansion % would be at the same but you would have more grout joints to buffer the effect. so if you had 10 98x98 with 2mm grout joints each tile would expand by 0.0056mm...... which is naff all.
Tile Shop
Coefficient of Linear thermal expansion?
I remember dealing with that for sheet lead. It’s fascinating stuff, kind of :D
Thats the one. We probably have different definitions of fascinating :)
Easy when you know the equation but still need to know the CoLTE of a particular material. Basic ones I work off are as follows. But as you can imagine, its not something I need to use very often:
Porcelain 4
Ceramic 6
Limestone 8
Marble upto 14
Granite 8.5
Plaster 17
Concrete 14
Wood variations 30 average
All true, but if standards are looking at expansion rates over a temperature range of zero degrees to
30 degrees C then is it possible they are justified in their findings?
(It’s late and have no intention of working the equation now)
The problem there is that it’s not a credible theory, typically materials that we install are already acclimatised, and if not, they should be, so if the residence is occupied, the tiles will not start at a temperature of zero degrees, they’ll probably already be 15 degrees and over.
This would be more in line with amounts of expansion mentioned above, and not from where standards may be taking their calculations from.
Just a thought.
It also happens to be the biggest and easiest get out clause in the trade.
Tile Shop
The above examples i used were starting at 20 and BS would probably account for extra tolerance to be safe. The expansion is based on the difference in temp only which is closer to reality rather a "but what if" extreme. So for julians instance of ufh, going to 34, means the figure is calculated on the 14 degrees difference. If it started at zero and went up to 34, the expansion would be far greater........... Will work that one out in the morning :) ...zzzZZZ
Hello, we are currently in dispute with a builder over a poor bathroom installation which includes poor tiling and also poor fitting of goods.
The builder has all of a sudden asked that the British Institute of Kitchens Bedrooms and Bathrooms do an inspection. We were thinking the Tile association would be better but they cost a lot (750 plus VAT).
Does anyone have experience or dealings with BIKBBI and if so does anyone know if the standard of their inspections would conform to British standards and Tile association standards for tiling ?
Does anyone know anyone else or where else we could get an inspection done. The builder used dot and dab also but i understand that most inspections would not remove tiles off the walls ?
Reply to Important Changes to Tiling Standards in the Tiling Standards area at TilersForums.com
Hi everyone, this is my first post so thank you for reading my question. I am looking to...
Hi there, I had an en-suite tiled in July 2017, we noticed a leak in the hallway in December...
I keep this to hand now so I can show customers Tuesday, 24th July 2018 Important changes to...
Unused Account 1
U
Hi All, I’ve just had 2 rooms tiled with oak effect ceramics and I feel a little disappointed...
5K
Tiling Standards
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
