Guest viewing is limited
Discuss Tiling tips 2015 in the Australia Tiling Forum area at TilersForums.com.
Rizzle from the Portizzle
Haha don't think so!
Funnily enough the first time I saw a 'Tiger Trowel' was at Ray tt's training day, didn't know they existed! Oooops!
Looked interesting tho, I believe Mark uses them a fair bit.
It has a unique seration, a proper solid bed trowel that I'm used to has a fairly small seration but has two large nibs, one either end, to keep the trowel off the floor effectively. So as u trowel it leaves a solid bed of adhesive behind with a seration on top.
Tiger Trowel
Solid bed trowel
Obviously lots of other trowels are classed as solid bed, but if I was being literal (not like me I know) :D
that's what would come to mind first!
solid bed trowel waste of adhesive and money the worst preforming trowel
tiger trowel more like a kitten ***** if you have loads of money to waste on adhesive you dont need this is the trowel for you
if any of you own one of the above put it under glass and have a look
Well I was just asked what the difference was Ray,
Never did I say I use them or even own them (which I don't)
Hope this helps! Hahaha
Spare Tool
To safely and accurately drill a hole through a tile I just drill a hole in a piece of 6mm MDF or Hardibacker first with whatever size bit I'm about to use.
Then place that on top of the tile (with the pre drilled hole over my intended hole in the tile), then fill the cavity with water, place one foot either side of the hole and usin the board as a template drill through!
Using this method the drill bit will not wander, which means u can also drill right up to the edge of a tile and it not break out!
I also find standing over the tile enables you to have total control of the drill and keep it perpendicular to the tile.
I always use my large variable speed SDS drill for drilling tiles, it has masses of grunt, the bits don't snag and it's a comfortable height to work with, rather than a combi let's say.
Simple but effective.
Used this today on a few holes, better than suction, water pump devices..all holes landed bang on centres ;)
Reply to Tiling tips 2015 in the Australia Tiling Forum area at TilersForums.com
  • Sticky
  • Article
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread...
12K
Hi everybody, I've come up with a new way that I'd like the forum to work. I've built a quick...
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
Tiling tips 2015
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
