Tilling on a floor with Karndean already on floor & underfloor heating
Re: Tilling on a floor with Karndean already on floor & underfloor hea
hang on, no need for all the no-sayers to get so huffy.
my advice to the raylincs is to show copy of this thread to your customer. Give him 2 quotes: one for tiling directly over karndean; and one for taking the karndean all up.
give him your own professional opinion, and then let the customer decide what he/she wants you to do.
then let the forum know what happened next.
don't see how you can wrong.
Hi ythan
Thanks, that's what I have decided to do, and if they decide to go with leaving the Karndean down, then I will get them to sign and date a quote say they will take resposibility if the tiles fail.
This is the first time I have posted on the Forum, and thank everyone for their input.
I will let you know what happens!
Hi ythan
sorry but that don't mean jack in a court...just hope you get away with it and if you don't I hope they don't use my advice...
Take advise off those qualified.......a little bit of wisdom given to me in my life.
dave has been a tiler since god was a boy, and ajax is the screed pro on the site. Anyone with half a brain would listen to the FREE advice that has been given.
if the customer does not listen, then let some other cowboy do it. not worth losing rep over it
i asked for a description of the possible mode of failure - ie how, where and why is failure predicted to occur.
do any of the no sayers have the technical ability and time to do this?
talk of court action is frankly ridiculous. i'm also taken aback by the apparent lack of respect for customers views/wishes, and also by bully boy tactics.
bal single part fastflex is a great product designed for underfloor heating and a variety of substrates including vinyl.
it's much easier to use than bal 2 part fastflex & costs significantly less. no doubt other manufacturers have similar products.
i wish raylincs and his customer well.
1. do any of the no sayers have the technical ability and time to do this?
2. talk of court action is frankly ridiculous. i'm also taken aback by the apparent lack of respect for customers views/wishes, and also by bully boy tactics.
3. i wish raylincs and his customer well.
1. not lacking ability but deffinitely lacking inclination. There are several potential failures and my main concerns revolve around the "weak screed".
2. If it is wrong and it fails the customer has a legitimate claim against the tiler. if a tiler is happy to put himself in this situation then fair enough. The customer is not always right and having him sign and date a peice of paper to say he takes responsibility is not generally a lawful defence. Worst case it goes to court.
3. Good stuff, that's the spirit 🙂
Thanks for your response, Ajax.
I'm happy to give further explanation of my viewpoint.
Regarding uncertainty about the quality of the weak sand/cement bedding. Given that the karndean has remained firmly stuck down, and is showing no signs of damage e.g. no mention of legs of chairs punching into the karndean etc this shows the substrate is stable and completely adequate to take vertical loads.
The floor has underfloor heating so there will be horizontal stresses and strains set up within its depth, as the floor heats up and cools down. As the floor has been in use for some time any cracking, shrinkage etc in the bedding will have mainly already occurred, and the karndean (being elastic) will have helped distribute the stresses such that any cracking in the bedding will be micro cracks.
So I think:
- Leaving the karndean in place may well assist the bal single part fastflex to safely accommodate/distribute thermal stresses and strains through the interface between the stiff solid tiles and the sand/cement bedding.
- Leaving the karndean in place will make the job much easier, cleaner, quicker and successful for raylinc and his customer.
Just one little point, given the tiling is likely to be done in cold weather, it could be a good idea to set the floor temp to say 12/15 degrees to reduce the subsequent thermal stresses when the floor is in normal usage.
All considered comments welcome.
Hi Raylincs
Karndean needs to come up,if you tile on top whether you use flexi or not the tiles will come away from the karndean.Do the job as it should be done and there wont be any probs
Tolola2
Single part fastflex
USE FOR:-
Most types of FLOOR tiles including:
  • Ceramics
  • Porcelain and fully vitrified tiles
  • Mosaics
  • Natural Stone including marble
  • Slate
Most substrates including:
  • Asphalt (suitable grade e.g. flooring)
  • Concrete, cement:sand screeds and rendering
  • Existing vinyl tiles, unglazed ceramic tiles, quarry tiles, terrazzo and natural stone
  • Fibre reinforced cement boards and lightweight tile backer boards
  • Tongued and grooved floorboards
  • Underfloor heating
It doesnt say karndean/vinyl tiles layed on a sand and cement screed with under floor heating ,and thats where the problem would be if a failure occured.
Am not saying its right or wrong to tile on vinyl as a lot of reps around the country would recommend a product to do so and would believe in that product,i will say when asking a rep that they know the exact substrates involved.
mz30 - welcome any comment on my last post above re the sand/cement bedding.
is this a job you'd have simply walked away from?
No i wouldnt walk away until i had all the facts,from what has been posted by the o/p the chance of failure is there but does not mean it will fail,there is a chance on every instalation of failure regardless of measures taken, as tradesmen we have to eliminate as many foreseable problems as possible.
Unfortunately a lot of guys on here put the cart before the horse and say everything they disagree with is destined for failure and then the people reading it think i'll post the same and i'll be right,always a problem with forums.
Jobs like this are fairley simple to me.....give the customer a quote to rip up old and fit new....if they say no.....so be it 🙂....at the end of the day customers WILL always get cheaper!.......BEER money some people work for these days and these are customers u dont want!
Hi All
I thought I would post an update.
After speaking to the builder who built the customers extension, the Screed isn't weak, a misunderstanding by the customer.
I have spoken and have an email from the Tech Dept of Kerakoll Adhesives and given them all the info regarding this job and they have reconmmended and confirmed that I should:
Clean & dry the floor, use Keragrip Eco Primer, and then affix the Porcelain Tiles with Marmorex Adhesive, Grout with either Fugalite Eco Grout (never stain/shade etc 2part) or Fugabella Eco 0-5 (cement based grout).
Many thanks for all the replies.
never used kerakoll marmorex so i'll be interested to hear how you get on. i guess it must be similar to bal's single part fastflex but maybe lower cost?
Hi ythan
I'm also getting Kerakoll to come out and spec the job, which will hopefully be next week, so i'll keep you updated.
Yes their Marmorex is similar to Bal Single Part at about £XX per 25kg bag.
raylincs
please note that bal do a single part flexible and also a single part fastflex.
the single part fastflex is much more expensive than the single part flexible, but it has much more flexibility to cope with under floor heating.
Bal single part fastflex costs about £XX per 12.5kg bag. Bal single part flexible is about £XX per 20kg bag. That's a big difference in bal products but justified i think.
but Is marmorex as good as single part fastflex?? and only costs £XX per 25kg bag??? blimey.
Hi All
Just an update:
I have had a site visit from the Kerakoll area Rep, who couldn't have been more helpful :thumbsup:. He has confirmed and as long as I follow their directions, they will guarantee their products for tiling on top of the Karndean :hurray::
Quote:
I can confirm that after visiting the site on 30th November,
Tiling to the existing Karndean flooring:
The Karndean must be well bonded to the subfloor and clean from any dirt / grease etc...
The recommendation/Specification from Kerakoll is :-
1)Kerakoll - Keragrip Eco (Primer for non porous substrates, to provide key)
2)Kerakoll - H40 Eco Marmorex (flexible/white/adhesive)
3)Kerakoll - Fugalite Eco (liquid ceramic grout, colour tbc)
4)Kerakoll - Fugabella Silicon, colour tbc.
I might also add, after my local tile supplier contacted Bal, and their Tech Dept have comeback and confirmed that:
Quote:
If the floor is in a domestic area or in an area of limited foot traffic and the Karndean flooring is well bonded to the existing substrate, clean and in good condition, it can be tiled using Bal single part fastflex.
I hope this helps anyone who may come up against the same problemas I have :thumbsup:
Just bumping some of the older popular (sometimes not so popular) threads. Probably wont be current discussion these days but I just need to do it. So just ignore the thread if it's not current for you.
I really think you need to contact adhesive manufacturers , If one say that you can do it then "knock your self out."
I have contacted adhesive manufacturers over doing something which I wasn't happy about . They said it would be OK so asked them to send me a written specification on how to do the job . They wouldn't. Question what does that tell you .?
Bal say it is good to go then go for it.... BUT when it fails , then see what response you get from Bal..
I shall not input anymore as cannot really add to the majority and cannot be assed to argue why with those that say it should be done... so as said above .. knock yourself out and don't complain when it does go **** up.
I can guess and it won't be don't worry we will send a technician to sort it all out as our adhesive clearly haven't performed as expected
I checked with Bal this morning and you CAN tile onto Karndean if,
The Karndean is not the cushioned type,
The Karndean is well fixed the the substrate,
The substrate is a concrete or sand/cement type,
And the Karndean is degreased prior to fitting the tiles.
And Bal don't usually mince their words, it's either black or white.
Funny you black or white I had limestone grout from them that was grey but they said it was limestone so that was OK by their standards .
I've just used 20kgs of Limestone grout from KeraKoll.......which strangely enough bears a striking resemblance to light grey!
Hopefully you get further than I did with bal . I even brought some more of their grout mixed it up let it dry . It was clearly a different colour but they said it was in their colour tolerances . Wasn't in my customers tolerances . I agreed and rectified it at my expense
raylincs,
Dumbo,
raylincs,
Dumbo,
