Discuss To turn on or not to turn on??? in the UK Tiling Forum area at TilersForums.com.
Ok clutches at straws now but what make of insulation board did you use and what thickness ?
hello,when fixing the boards did you make your adhesive slightly wetter so it bit right into the board to bond?
i find this better as a normal mix sometimes doesnt get the grab i need i find..just me though
how many bags of pro flex did you use on the 13 metre are for fixing the tiles slik can i ask?
Was this the cement faced board or the plain foam type.....6mm is too thin for me, i would say 10mm unless it was cement tile backer board.lol. . it was 6mm XPS Premium board (as recommended by the store i bought my heating mat from). . would this be an issue? (i hope not as it means the whole lot has to come up) :/
I wouldnt worry too much at the moment. I would cut the grout out to a depth of about 4mm and regrout those areas. See if it happens again.
Yeah I will do, just confused why it had happened. Whats the best and cleanest way to remove the grout? cheers
Was there any type of sealer or pre grout protector applied to tiles before grouting?
Could be that sealer got on edge of tile and prevented grout from sticking.
Reply to To turn on or not to turn on??? in the UK Tiling Forum area at TilersForums.com
