Discuss Trowel size for 600x600 floor tiles in the Best Floor Tiles area at TilersForums.com.
13
133
UK
Morning All,
I need to lay 600x600x10 ceramic floor tiles. I was wondering what the best trowel size for the job is please?
Thanks for your help
If the floor is perfectly flat, the smallest trowel I would use is 10mm notch, I would also back butter the tile. You need to get as near as possible to 100% coverage of adhesive on the back of the tile to insure it is properly fixed. If you lift a tile that you have fixed and you can still see the adhesive notches, then you haven't got sufficient adhesive coverage, so you will need to use a larger notch trowel.
Thanks for the help
The floor does run out. Shall I use a 20mm to be safe? Also will a u shaped trowel help with coverage?
Reply to Trowel size for 600x600 floor tiles in the Best Floor Tiles area at TilersForums.com
Some adhesives give info (not seemingly Mapei). I think the Mapei Standard Set Plus would suit...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
Hello I’m in need to find a box of this ceramic floor tile. My local company who put it in says...
Manchester
What member type are you?
  1. Homeowner
Business Name
N.a
Best Floor Tiles
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
