Expansion joint fitted between rooms. Note that the off-cut of the tile is carried through into the next room. You will need to allow for this when setting out.
I'd go for a Silicon filled joint too. With luck, you might find it works out ok if you set out with a full tile from the join between the dining room and conservatory.
