WetSaw
I'd do both.
It works on ready mixed tubbed adhesive, on a cement based adhesive might be a different matter.(Can't tell from the photo)Soaking tiles in a soapy solution has helped me in the past when I've had to rescue tiles ,normally 24 hours does the trick,then a bladed scraper to remove any stubborn addy from the back of tiles.
What makes you think you don't need new tiles? you haven't got all of the old tiles up and cleaned off yet.ok i have stuck it down using the adhesive but im not sure i used enough . Im tempted to get some quotes for removing all the tiles, putting plyboard down and putting the tiles back on. Its a very small bathroom and i dont need new tiles. and i have about 4kg of adhesive now 🙁
If i am to get quotes then should i say that this is what i want the tiler to do ? id be more impressed by a tiler who would say that plywood needs to be put down above the chipboard first as i would assume they were more knowledgable and experienced
Ray - best start a new thread!
