Discuss Ufh repair in the Australia Tiling Forum area at TilersForums.com.
CJ
1,088
Somerset
Not nicked a cable......but yesterday laid insulation panels, UFH & then self levelled. Never had enough self level compound........I thought it was going to be tight.........a few cables had lifted and poking up............had to scratch out, and push back a few cables.
Message to self for next job.......get more self level, just in case.
Stef
Ha, I had too much, had to pour about a quarter bucket into a couple of old bags of adhesive..
Stef
So where did you get said repair tubing from.
Eventually tracked it down to a Maplin store.
I had tried 8 or 9 different shops in Kilmarnock from electrical stores to car stores & then got tubing from the Maplin store in Ayr.
I had to slit the tubing to go round the wire & held it in place with long nose pliers till it set then got my glue gun & completely covered the repair so I had no moisture ingress.
Stef
Did you get any photos as you were repairing mate, never even knew UH could be repaired. Good post :thumbsup:
TJ I never took photos I forgot.
I never went right through the cable I only nicked the edge & exposed the outer earth wires.
Think of a co ax cable for a TV, you have your live & neutral running through the middle & then insulation then your outer wire is the earth then the outer insulation. The shrink tubing is only to stop moisture going into the earth wire.
If you did go through the entire cable then it can still be repaired, it's Ezewarm heat mat I use & they will send out a full repair kit if needed.
Reply to Ufh repair in the Australia Tiling Forum area at TilersForums.com
Hello everyone. My builder is going to lay my electric UFH today and I want to check he’s...
Today I had to replace a cracked tile. The customer said there was UFH under the tiles. I...
Marvo
Hi all Hoping for some opinions on how to handle an ongoing issue in having with my tiler He...
2 3 4
15K
Got onsite yesterday to find that the builder had laid the UFH mat, then covered it in SLC. I...
So, I'm doing my own floor, and for the first time I'm putting wire underfloor heating over...
5K
White Room
Ufh repair
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
