Discuss ufh thermostat - does the tip or whole length measure temperature? in the Canada Tile Advice area at TilersForums.com.
JimboD
The reason I ask is that I've just discovered mine will run right past a central heating pipe!
The wire will extend 2 foot into the room, but when it passes through the wall (thermostat will be outside of room - just using floor temp not air as well) there's a pipe there slap bang in the way. Sods law!
There's no easy reroute due to the rooms configuration.
Thermostat is Warmup one. It got a brass end cap so suspect its the tip only but not 100% sure so hence post. I wouldnt want the sensor to think the floor is nice and warm due to the central heating pipe when it isnt. :)
Cheers
Jim
Reply to ufh thermostat - does the tip or whole length measure temperature? in the Canada Tile Advice area at TilersForums.com
http://www.*************************.com/water-underfloor-heating-152-w.asp Supplying Water...
9K
Hi all Interested in views from the trade world about how I should deal with a big floor tiling...
2 3 4 5 6 7 8 9
41K
Hello, I'm new here, this is my first post! I'm due to get the keys to my new apartment in the...
mhtiler
    Votes: 5 4.5%
    Votes: 8 7.2%
    Votes: 7 6.3%
    Votes: 32 28.8%
    Votes: 14 12.6%
    Votes: 28 25.2%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.1%
    Votes: 18 16.2%
    Votes: 13 11.7%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
