Ultra Tile Backer Boards?? Similar to marmox
Now back to bare house brick and they not level, tiling a bathroom, shower over bath, was planning on using Marmox boards 12.5mm but tiling centre said Ultra tile backer boards same principle but cheaper, and have them in stock,
Was planning on dot dabbing marmox boards with flexible cement adhesive, then having to fix when dry with screws and washers, Now tile shop said normal fixings of ultra boards is to fully apply adhesive to board , but with walls nit level the best option.
They also suggested going back to mosisture resistant plasterboard and tanking as weight allowed is 32kg. Tiles are 300x600 8.2mm
Marmox have to order from tile experience then factor in delivery costs and delivery tiles, want the job done correct so if better option will wait for goods.
Will tile backer boards be a quicker process than the plasterboard
Use plasterboard normal dot and dab method, no worries at all, buy a tanking kit for around the bath area if needs be, but bear in mind, new build houses pass all British standard without marmox/tanking system in shower areas!
decisions, I was going to give the ultra tile backer board a go can get them for £8 plus vat for 12mm size, now not sure if they up to same standard as marmox they say the waterproof but was going to tank around the bath, as bought the mapei stuff from wickeS for £43 already.
2 of the walls in bathroom are stud walls so be a easy fix to that
Im annoyed with a few tile shops in north east when asked about marmox 12.5 they said it only came in 12mm, but the price they where giving me was for ultra, only after I queried why marmox did they do that size they then said are this board is Called Ultra
Where in the northeast are you based.
Inneedofhelpnewbie,
Dave,
Inneedofhelpnewbie,
Dave,
