Discuss unusual shaped hall in the British & UK Tiling Forum area at TilersForums.com.
mickdixon
Hi, I'm hoping someone can help me. I have a victorian house with the a typical hallway layout. Straight in from the door to the stairs and then it widens out to one side to lead to the kitchen.
There is one exception. The house is in a crescent and as a consequence is wedge shaped. The hall way at the kitchen door is 10 inches wider than that it is at the side of the stairs. It is 6 inches wider hear than it is at the front door. Is this making sense? (I'll try and put a sketch or photo up later if it helps)
I intend to use black and white victorian tiles with a decorative border. Do I set them out with the border running parallel to the walls or square the border and run it out outside of that?
I apologize for the dodgy descriptions but this is quite obviously not my field.
Any advice greatly appreciated
Time's Ran Out
scan0011.jpg Its a question of aesthetics and customer choice I think.
Apart from my recent entry on Job of the Month (August) I always set my hallways out for the centre field tiles and make sure I have an equal cut to the border - especially if it is on the diamond ( for some reason I never do it square - must be something to do with long straight lines).
However it is not always possible in areas further back from the main door to follow exact patterns back towards kitchens etc. and you then have to position the border as the main emphasis.
The area outside of the border is your variant section and cuts can run from 20mm up to whatever - even 120mm each side is ok rather than seeing the pattern eaten into the border.
I have included a Black&White to show the layout.:thumbsup:
Hope my input is of interest.
Timeless John.
mickdixon
Timeless John
The photo is pretty much what I am trying to achieve but the border is slightly different( triangles instead of full tiles). I did read somewhere that sometimes on original victorian halls the border ran straight into the stairs to give the appearance that the stairs were built on top of the tiled hall. I presume this means there would be no border required along the side of the stairs too. Does this sound plausible ?
Regards
Mick
Time's Ran Out
Mick - I'am pretty certain that the staircases would have been in situ prior to the tiling as the hand made Goemetric tiles of the Victorian era tended to be about the border following the shape of the Vestibule/Hallway.
To me for it to run into a feature ie wall/staircase would give the appearance of it being built on and IMO loose the feature as a unit.
The photo above shows the off set feature of the hallway going back to the scullery/kitchen. Here as I described in my earlier post it shows how a design has to accommodate the uneven position of field tiles and thus the border becomes the prime feature.
In this example we were just the tiling contractors and as such had no initial input to design/colours and therefore were governed by the pattern for layout .:thumbsup:
Timeless John.
White Room
Timeless John
Regards
Mick
Did see that in an old property, they also laid the tiles under the stairs
Reply to unusual shaped hall in the British & UK Tiling Forum area at TilersForums.com
Hey guys, I normally post over in diynot for general DIY but wrt tiling over timber I need some...
28K
Just Rizzle
Hello. This is my first post, so thank you for letting me be here. I'm hoping someone with more...
8K
11K
Rizzle from the Portizzle
I've just bought 85m2 of these Limestone Tiles The sub-base consists of a wet UFH system...
18K
Spare Tool
I
I'll set the scene. The in laws invited us round for a BBQ yesterday, and these are always well...
unusual shaped hall
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
