URGENT! need advice TODAY, horizontal staring point (see drawing)
Around edge of bath on door wall?
Do you mean running down the side of the bath?
Where the cross is?
Just move the joint up to the bath, from your drawing it doesn't seem to cause an issue.
The slither above the door is more difficult and tbh where it is, and how the rest of the room works, I wouldn't worry about it.
It runs in to the wall and is behind you when you enter.
There will ALWAYS be a compromise to make, we just do what we can to lessen the impact.
You can always fit a piece of 30mm timber on top of the architrave, fill it well and paint, probably be unnoticeable.
The architrave will just be taller.
It will depend on the profile of course.
Thanks again, yes where the cross is. I think I'm just being a little obsessive at this point.
Full tile off bath
The tile above the window sticks out by 5mm either side as the window is 590mm and the tiles are 600mm. Also 74mm tile all around where wall meets ceiling. What do you think.
Drop everything by 1/3 tile even up floor and ceiling line cuts. Reduces over bath to 2/3 tile and balances cuts too and bottom of window.
Presuming this works for the rest of the room bingo!
jimbob,
Andrew,
jimbob,
Andrew,
