Walls and Floors?
I
IvegotsTILE
I was just wondering who uses their washboys for walls and floors?
I used to use it for both but now I only use it for floors because of the effect it sometimes has on the grout on the walls.
Maybe Gaz or Dave can turn it into a poll!(don't have the know how)
use mine on both and couldnt do without it now. you have to let the grout set just right and use the washboy lightly diagonally over the joints.
Simon maybe you are not leaving the grout on long enough before using washboy.What i do is start at one wall and by the time i get finished the others the grout is drying and then i swirl the sponge OVER THE GROUT LINES and move on to the next wall etc and when im finished doing the spongeing i then wipe with washboy.Give it a go m8,but sometimes you need to work fast,heat etc.:thumbsup:
The only time I don't really use my washboy is on kitchen splashbacks as they are often too small and fiddly for the washboy sponge, other that that I use it for everything.
on floors and commercial walls and say penny rounds that type of mosaics where there are larger walls but not top notch domestics 😛ete
Walls and Floors?
IvegotsTILE,
IvegotsTILE,
IvegotsTILE,
IvegotsTILE,
