Guest viewing limit reached
Weber Set Trade S1, real problems!
I am reading this post with interest. Looking at the pictures it does look as if you have used enough adhesive but the adhesive has compressed and hasn't taken a bond to the ply.
Personally I would use the same batch of plywood. Do a control test, I.e use the same weber adhesive and fix one tile to the ply. Then use another adhesive (bal, mapei etc) and fix another tile to the ply. Make sure you use the same ply that is on the floor as that may prove the ply is at fault, if however one of the other adhesives take to the ply then the weber adhesive is at fault.
Hope you can get this sorted out.
I had had the same thing happen a couple of weeks ago on a small bathroom floor using Webber trade adhesive at the time I didn't think it was the adhesive just thought the ply was dusty I tiled it again using mapei had no problems after seeing this post I'm pretty sure it was a adhesive problem
Is it a coincidence or something else, but that adhesive is not listed on their current website dated copywrite 2017.
And if @impish says it's been around for 18months, shouldn't it be there?
It is advertised on Ctd's site tho.
Do you think this is ctd only adhesive at a cost that they can make plenty of money out of it .
My CTD sell a lot of it. apparently.... not to me, cheap is not always best
After waiting 7 days to even get anyone to look at this floor and then another 4 days I get this ridiculous email from Weber! I told them I'd used WBP hard wood ply which has Mahogany in it. They're telling me not to use ply with Mahogany in it! Now can anyone tell me of a hard wood WBP ply which doesn't have Mahogany in it??
My conclusion is if you ever have a problem with Weber then tough luck as they'll do nothing to help. AVOID THEIR PRODUCTS!!
Observations:
The tiles had been fixed to a high standard with a full bed of adhesive. The ply that had been used as a substrate was described to us as being a mahogany hard wood. The tile adhesive is our weberset rapid trade S1 product.
The Mahogany ply is also known as “luaun” and is not a suitable substrate for tiling. The veneered mahogany surface is glued to the board using water soluble glue which softens when exposed to moisture from the tile adhesive.
We understand that another manufacturer’s product was used to bond tiles to the ply and this worked with no failure.
Recommendations:
We would recommend that the ply is removed and an 18mm WBP ply used to replace it. WBP ply is water and boil proof and should be primed on the back and edges. The boards should be screw fixed to a joist or a noggin at 300mm centres. Tiles can then be re fixed with a solid bed method as used previously.
Billski,
aussie tiling,
Billski,
aussie tiling,
