Weber SPF rapid white
I've just took delivery of 20 bags. I ordered the slow set white and received the rapid. Will check the date on mind Monday when i get back to site.
Is this your London work Bri? Where'd you get it from? Local or did you bring with?
It's from worlds end in Battersea.
Well it was set rock solid this morning so, all is well. I just hope it was SPF in the bag and not SP!
The rapid set has 'low dust' technology. The slow set doesn't. So if you poured it out of the bag and you got engulfed in a plume of smoke then it's slow set in a rapid bag.
I had the same problem with Weber rapid spf grey this week. It took 3 days to go hard. There was no heating in the house and I overboarded the floorboards with 6mm Hardie, UFH & SLC. I could still scrape out the adhesive from the grout lines after 2 days!
I wouldn't worry too much about it Bri as it will lift in 6 months as the "Dabs" were too big!!!
Nonsense, I only put 5 dobs on each tile so there was plenty of air circulating around to dry it out quicker 😉
Your generous bri. Credit crunch has hit hard in south wales so I reduced my blobs down to 4. Gotta think of my back pocket
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
