Perry
Dave you dont need us lot mate you have been around to long lolIt is just as you guys think..its the moisture from the adhesive and grout causing it to swell slightly and dry back but still leaving the hump......I tend to either take the wood cill off or board over with plasterboard........also if leaving the timber cill on then it is worth putting a couple of extra fixings in to make sure it is solid....
you should always use rapid on timber even ply as you can get the same problems😛ete
