Discuss What is the hardest tile you have came across to cut? in the Canada Tile Advice area at TilersForums.com.
Tile Shop
viper, is no good for 20mm.
You need a blade, which downloads quickly, debris.
Otherwise it will heat up. I can only tell you what he told me montoit.
size?
ND 200 so 200mm blade...... 600x600x20mm tile. It worked and it was fairly neat. but did struggle.... took a good few minutes but didn't count how many. The battipav I did in 3-4 passes with the Battipav 300 fast-cut [serrated] wheel.
I
Italy
Some cuts, I used sigma 100cm.
(The easier ones).
The rest, with montolit tcs 115, clean cuts.
Or montolit txn 115, faster, but not clean cuts.
I posed, 40x100x 20mm, I think .... ahaha
I do not remember anymore.
@antonio
Reply to What is the hardest tile you have came across to cut? in the Canada Tile Advice area at TilersForums.com
Hi Guys, I’ve have a job coming up to install lily pad porcelain hexagon tiles. It’s the first...
Hi guys, i took some jobs as a contractor for some MC Donald's restaurants but i find it quite...
Im going to be tiling my shower room walls and floor with some large format tiles as per the...
5K
    Votes: 9 5.5%
    Votes: 17 10.4%
    Votes: 12 7.3%
    Votes: 46 28.0%
    Votes: 21 12.8%
    Votes: 39 23.8%
    Votes: 4 2.4%
    Votes: 3 1.8%
    Votes: 22 13.4%
    Votes: 19 11.6%
    Votes: 17 10.4%
    Votes: 8 4.9%
    Votes: 5 3.0%
