Discuss What tile adhesive is used for large format tiles? in the British & UK Tiling Forum area at TilersForums.com.
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
There are adhesives available that are safe enough for bathrooms. The problem is with cement based adhesives for walls it this, A) if it's cement V plaster, you have to prime it, the cement and plaster don't mix well and bond can become free in the future B) cement based adhesive are not waterproof, they're water resistant, so they allow water to pass through them and they don't break down, but the plaster or plasterboard behind will and can.
I suppose providing you can tank the shower / bath area though, and prime the rest (if plaster), you'd be fine.
In my opinion.
Deleted member 15
regardless of adhesive used, plaster and plasterboard should always be primed. Paste is normally Polyvinyl acetates or PVA which itself is waterbased, and if it comes in contact with water, it will liquify into its normal state. So thats why i only use cement based adhesives for bathrooms, Especially around the bath and and shower.
Deleted member 15
how do u mean pre-primed, like acrylic paste. You still need to prime especially plaster, because it is highly absorbent, and it will draw moisture from the product , waterbased or acrylic
But really for all it takes no way i wouldn't prime plaster or plasterboard
better to be safe than sorry, I always prime with a SBR bonding agent
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
Found an article on the TTA website which point 14 states at the end "Where the use of a primer is recommended before the tiles are fixed the recommended primer should be applied strictly in accordance with the manufacturer’s instructions.Where the use of a primer is recommended before the tiles are fixed the recommended primer should be applied strictly in accordance with the manufacturer’s instructions."
TTA Website said:
When fixing ceramic wall tiles to gypsum plaster surfaces on masonry backgrounds you should keep the following points in mind:
  1. Although ceramic tiles can be fixed to a wide variety of backgrounds with appropriate adhesives, most tiling is fixed onto cement-sand rendering, gypsum plaster systems or onto plasterboard.
  2. Cement-sand rendering is the preferred background for tiling and detailed guidance is provided in British Standard Code of Practice BS5385 Wall Tiling (BS5385-1, BS5385-2 and BS5385-4). Less information is provided about gypsum plaster backgrounds and this joint statement has been prepared in order to emphasise the conditions under which gypsum plaster can be safely used as a suitable background for ceramic tiles.
  3. It is very important that the masonry background is thoroughly dry. A minimum of six weeks should have been allowed between the construction of the masonry background and plastering. The presence of moisture in the background will not always be visually evident.
  4. This is particularly important where gypsum plastering is to be applied onto concrete walls especially if of lightweight or aircrete (aerated concrete) blocks or onto insitu concrete walls or onto cement-sand rendering.
  5. Caution: Cement-sand rendering dries gradually with shrinkage taking place. If a cement-sand undercoat is not cured and dried prior to plastering and tiling, the subsequent drying shrinkage of the rendering can break the adhesion between the undercoat and finish coat of gypsum or between the finish and tile adhesive causing failure. New concrete walls require a longer drying time to allow shrinkage to take place, otherwise similar problems will occur. The same is true of existing concrete walls which have become saturated in use.
  6. If plastered or rendered walls are to be tiled, this should be decided in advance of plastering, and should be given as a separate item in the Bill of Quantities and contract specification. See item 19.
  7. Plastering should be done in accordance with the recommendations given in BS5492 and modified in BS 5385-1 section 3.4. The plasterwork should be firmly adhered to its background and be sufficiently strong to support the specified tiling.
  8. The maximum weight of tiling which can be supported by a dry, well-adhered plaster background is 20kg/m2, generally equivalent to ceramic tiles with a thickness of 8mm or natural stone tiles with a thickness of 7mm. When fixing directly to unskimmed paper-faced plasterboard surfaces the maximum permissible weight is increased to 32 kg/m2. These weights include adhesive and grout.
  9. Proprietary gypsum based systems are recommended because both the undercoat and finish are designed to work together. Advice on which finish coats work with which undercoats is available from the manufacturers.
  10. Gypsum plaster must be thoroughly dry before tiling. New plasterwork consisting of undercoat and finish coat should have been completed at least 4 weeks before tiling is commenced. Tiles should never be fixed to plaster which is not dry throughout. Where drying is assisted by space heating or dehumidifying, care should be taken to ensure that the plaster is not just dry at the surface. The heater or dehumidifier must not be directed at the plasterwork.
  11. It is important to understand that some gypsum plasters may appear dry on the surface whilst still containing moisture within.
  12. Use of non-invasive radio frequency moisture meters will be of help in determining moisture levels still within rendering/plastering and/or the background.
  13. When it is known in advance that tiles are to be fixed to a plastered wall, it is essential that there should be good adhesion between the undercoat and the plaster finish coat. Tiles should only be fixed to the finish coat and must not be fixed directly to a gypsum undercoat.
  14. The finish plaster should be specified and applied to provide a matt finish. Excessive trowelling of the plaster to ‘improve’ its appearance must be discouraged, since this practice may result in a dusty or shiny surface which is not suitable for tiling. If the finish plaster is hard and sound but has dusty or friable residues on its surface, the surface should be thoroughly brushed down. If trowelling of the surface has produced a shiny and smooth surface, this must be removed by vigorous brushing. Where the use of a primer is recommended before the tiles are fixed the recommended primer should be applied strictly in accordance with the manufacturer’s instructions.
  15. Every plaster surface should be examined carefully by the tile fixer before any tiling work is undertaken, paying particular attention to surface finish. In addition, it is important to sound the whole area carefully for any evidence of hollowness or lack of complete adhesion in the backing. Any such defects must be remedied by cutting out and replastering before tiling. The repair must also be allowed to fully dry out.
  16. On old plastered surfaces any decaying or loose areas must be cut out and made good.
  17. Sometime painted plaster surfaces are encountered. Hard gloss paint if well bonded is usually a satisfactory base for tiling, but any paint showing signs of flaking should be removed. Emulsion paint or distempers can break down after tiling and must be removed mechanically prior to tiling. The surface to receive the tiles must be clean, sound and dry.
  18. Since thin-bed adhesives not exceeding 3mm bed thickness are generally specified for fixing tiles to plaster, the plaster surface should be plumb, true and level. Trueness of surface should be such that when checked with a 2m straightedge, any gap between points of contact should not exceed 3mm. Note: However such close tolerances of the trueness of a plastered surface will not have been attained unless the surface was specified to be tiled prior to plastering and the appropriate specification for plasterwork defined. Explanation a plastered surface, which is not to be tiled, is not required to meet such tolerances.
  19. Generally, ready mixed adhesives conforming to Types D1 or D2 of BS EN 12004 are appropriate for fixing ceramic tiles to properly prepared plaster backgrounds.
  20. Where fully vitrified large format tiles (under 20kg/m2) are to be fixed the recommendations from the adhesive manufacturer regarding adhesive and surface preparation should be sought.
  21. Plaster is not a satisfactory base for tiling in wet areas e.g. shower compartments. Reference should be made to BS5385-4 for tiling in wet areas. If the backing consists of existing gypsum plaster seek the adhesive manufacturers advice on suitable waterproofing systems.
Note: this is Tiling to Gypsum Plaster
H
Harry the tiler
if only new plaster walls had a max of 3mm tollerance i would be one happy tiler, ive yet to find a plasterer thats bothered to get the walls that good, dont think they ever get a straight edge out the van, interesting about the natural stone weight issue most stone is 12mm thick, must be a lot of over weight stone walls out there!!!!
m3 fitter
smiths said:
Why would you want to mix adhesive if you didn't have to?
ready mixed sticky is fine for small (less than 300x300) ceramics, large format or natural stone wall tiles, it hasn't got the mechanical long term fix of a single part powder, you can adjust your notch tolerance without worrying about curing capabilities... when you move up in the world with tiling ;) tub gear becomes obsolete ;)
Mudster
Technically an SBR primer is for slurry priming concrete floors and sealing the edges and back of wood substrates before tiling.
For priming gypsum plaster walls or plasterboard you should be using an APD primer. (Read BAL's techinicaly literature for a chemical explanation on why this is).
Mudster
Indeed, I have a big problem with 12mm Travertine being sold as wall tiles, Topps sell it, Fried Earth sell it, in fact all the major tile retaillers do and it is pure ignorance on their part that they continue to do so.
New regulations have been introduced this year that makes them legally responsible for the advice they give, which up to now has been the responsibility of the installer no matter what the retailler says.
Reply to What tile adhesive is used for large format tiles? in the British & UK Tiling Forum area at TilersForums.com
Best Tile Adhesive for Walls and Floors 2008 Pro Tile Fixers Poll - TF Tile Suppliers Best Tile...
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi folks, We're having our downstairs tiles installed soon, about 82m2 of 1.2x1.2m square...
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
