Discuss What tile adhesive is used for large format tiles? in the British & UK Tiling Forum area at TilersForums.com.
stevep1
the technical info on the palce web site, regarding their tilers' primer, claims that it's a S B R and suitable for priming gypsum plaster before tiling with a cement based adhesive. I have had a recent failure with this and have since read that maybe i should have used an A P D primer.Confused and fed up now. Been tiling many years. Feel like i know less now than when i started. WE used to PVA EVERYTHING AND JUST TILE. Any advice welcome.
stevep1
all the tiles in a marble bathroom 600 x 400 tiles. and all the tiles in another bath room. 900 x 400. ceramic came off when de pegged. the walls were primed and single part flexy was used , as i have done thousands of times before. have since tested other adhesives and primers and even not priming and cant get a tile to stick. they come off clean not leaving a mark on the wall. have sanded walls back . tried everything. thing is a length of trim i put on with white star tub gear stuck like you know what. shame i cant use it on such large tiles.
DHTiling
This could be a number of things..
Either you are using insufficient primer or spreading to much addy and it skins off before you press tiles into situ or incorrect fixing method.
To have failures job on job then it must be fixer error.??
stevep1
just to make it clear they are two bathrooms on the same job. we tried neat primer this morning and fitted a tile with rapid two part flexy. then fixed it correctly. it came off not leaving a mark on the wall. apparantly the walls were plastered in sub zero damp conditions. if i didnt know what i was doing i'm sure i would of had failures in the past 15 years.
DHTiling
I suggest you wind your attitude back a bit..:thumbsdown:..
Does it say on the bottle to apply primer neat..?.. not many i know say apply neat.
Tiling for 15 yrs.. maybe so but does that mean you have done it right for 15 yrs..
we are here to help and having a dig gets you no where...
How long have you left the primer to dry before tiling.. how old is the plaster.. at what temp are you tiling....like i said loads of reasons..
stevep1
tried everything. been in every morning this week just to try some new primer or addy. started with benferfix then benferflex then palace spf. diluting primer,one coat ,two coats, none. spreading wall,spreading tile, spreading both,dobbing. think he might have to cement board over plaster. thing is 4 houses 5 bathrooms each. alot of work. would rather find something that sticks. never seen anything like it.
Reply to What tile adhesive is used for large format tiles? in the British & UK Tiling Forum area at TilersForums.com
Looking to lay large format (900x900mm) thin (5.5mm) porcelain floor tiles onto a sand and...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hi folks, We're having our downstairs tiles installed soon, about 82m2 of 1.2x1.2m square...
Dan
Staff member
Admin
Staffordshire, UK
Website
https://www.tilersforums.co.uk
What member type are you?
  1. DIY Wall and Floor Tiler
Business Name
Ekthetikos / untold.media
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
