What tips have saved you time or money?
regularly reading the forum!
Had I not read of such a thing as anhydrite screed when they started to appear then I might have just thought the first one I came across was just normal screed and not prepared it correctly, etc.
So check on the forum and any other relevant data sheets etc. to keep up to date with techniques, products, tools etc. etc.
That's what it's all about SJPurdy, the whole point of this forum is to improve the trade accross the board, or am I wrong?
Anyone that says they haven't been bettered by reading this forum is in my book a liar!
I do not know what to say......
from October, I learned many things, the first thing I learned was to raise prices. hahaha
misstiler, introduced me to vinegar for Epoxy. other small things, I have stolen, here and there. I do not remember .....
marc administrator (the Samaritan) ....... I thank you .... if there was no marc, I do not think that I'm still here.
So, for a few months, you have to endure. haha
vinegar for epoxy?? what is the use of that mate? i guess some chemical reaction?
Switching to sigma cutter that saved me a lot of time. Marking cuts on tile with pencil without using mesure tape saved me a lot of time as well. Keeping workspace tidy and organised saves a kot of time as well. Using braces saves you time on pulling your trousers up. Few seconds here and there thats in some cases 1 hr a day.
Some people just don't like change my dads a rubi guy through and through he bought a sigma and hated it he just couldn't get used to the sigma way but I think it's great so It now lives with me lol
Not having someone who says he can tape up the joints in plasterboard do it for me would have saved me loads of time and money. Why say you can do something when it's bleedin' obvious you can't? I've now got to do it all again..... It's also reminded me why I generally work alone.
Not changing from a Rubi has saved me a lot of time and money!!
haha
Get 2 identical tape measures and keep one in the room your working in and one where you're cutting.
This is a good tip but beware some identical tape measures can read slightly different! The bent bits on the end can vary a bit. This drove me mad when it happened to me - my cuts didn't fit until I realised why.
An oak framer I know told me to always use the same tape to measure and cut. It's something I've always done since and it certainly sharpened up my accuracy.
I recommend the ones from Tradetiler - very consistent. I must get through 6 or 7 a year and love the fact they're metric only!
The only problem with my tip is that I go to measure and still can't find a tape because they're both sat by my cutter outside!
Never do work for an engineer !!!!
They think they know everything !!!!
And will drive you nuts !!!!
Seriously....if you see one coming towards you hold a sheet of graph paper..RUN !!
I worked for a aircraft engineer he went over everything with a magnifying glass at ome point he pulled me over 1mm discrepancy over a 10tf span I had to stop him and say Mr burgess this isn't a aircraft wing it's tiling and to be fair he did let me do what I do after that
Dan,
White Room,
Dan,
White Room,
