jay
hi all had a call from grumpy lady on monday she recently purchased a unit i tiled 5 years ago she told me the tiles were falling of shower walls and what do i intend to do about it. set up time to have a bo peep. very cold reception on arrival .she has a leak in shower wall and called her insurance . they viewed and checked plumbing (removed tap cover plate and looked ) no leak was there call just shody work by tiler no waterproofing . ( standing in large self dug hole) i informed grumpy lady it is waterproofed (dont think she belives me) what i did originally was render concrete floor of shower cube for falls waterproof walls and floor fix floor tiles including waterstop to shower door area fix tiles to two walls of shower and total area of hob grout and Silicon .(standard stuff ) now shower didnt look pretty at all tap wall bowed out around taps 6mm tiles solid grout hairlined cracks (exp with bow) back wall fine .hob sh-- not good (1mx1mx120mm) all external edges cracked wide open 4mm at top ledge down to 1mm at floor tiles all solid grout had seen better days all Silicon in shower good .on top of hob now sits (didnt see finished bathroom) glass panel on outer edge of hob top (65 to 70kg in total top tiles on hob are now 4mm above chrome edge on inside wow but all solid (hole getting deeper) so whats next . i remove tap cover plate (mixer) joy can see waterproofing show grumpy lady. gap between p/b and tap fitting void (plumber hasnt siliconed up ) suggest to grompy lady this could be her prob same goes for shower fitting .she agrees as for hob shine torch down cracks and show g/l w/p in tact .she tells me org builder said its constructed of treated timber frame covered in cement sheet.( and yes i checked the building code and you can use treated in bathrooms ) builder said water must be getting into treated causing it to swell not his prob (must have been a brain surgeon in prev life ) okay tell g/l ill check with my ins to see what happens here and suggest she rings builder reg gaps around tap fittings. my ins said do not touch anything or you are addmitting fault and its builders fault due to voids around taps.(you learn something every day never used my insurace before) got a call from builder telling me its my fault and i have to fix or my name is mud arguee with him for 20 mins and then realize mobile will hang up if thrwn 20m or more (hole is way to deep) okay that is part 1 sorry for the length couldnt shorten now what would you do post replies ps builder also informed me he has contacted master builders association (think i might strike oil soon big hole), part 2 soon true story :8:
