Discuss Whats everyone using to stick down Ditra or durabase onto Ply subtrate in the Canada Tile Advice area at TilersForums.com.
Jeff the tiler
Re: Whats everyone using to stick down Ditra or durabase onto Ply subt
There are different makes. Schluter seem to recommend Ardex or F.Ball F44 which for 5 litres is around £20 but you will get circa 15 to 20 mtrs out of a 5 litre tub with a 3 to 4 mm trowel. I have just seen on ebay 15 litre tubs of amtico's equivalent for £40 so if you are getting let's say 55 to 60 mtrs, comparing flexi addy @ an average say £12 a bag getting 6/7 sq mtr coverage would cost you circa £100/120.
The above are only a indication, and no I am not trying to flog the stuff, but it seem to financially a better bet where applicable.
John Benton
1,138
Leeds
Basically as it is such a thin layer of glue [but please check reference wet rooms] you can pretty much work on it an hour later after fitting the decoupling membrane.
I have used the F.Ball F44 to fix Polyfloor. Although you can walk on it after an hour or so, but don't forget you generally have to leave it at least an hour as well before you lay the Ditra on top. The glue has to almost go off similar to a contact adhesive before fixing.
Reply to Whats everyone using to stick down Ditra or durabase onto Ply subtrate in the Canada Tile Advice area at TilersForums.com
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
  • Sticky
Hi Guys What are your opinions regarding the usability between Ditra and Durabase matting? I do...
2 3
29K
Hi I am after some advice on the following, I have been to look at a job which had problems in...
8K
shick
Hi there 1st time poster - long time lurker so be gentle! I'm in a bit of a quandary and would...
10K
Qwerty
Q
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
