Guest viewing is limited
Discuss Whats everyone using to stick down Ditra or durabase onto Ply subtrate in the Canada Tile Advice area at TilersForums.com.
peteablard
1,058
Cheshire
Re: Whats everyone using to stick down Ditra or durabase onto Ply subt
There are different makes. Schluter seem to recommend Ardex or F.Ball F44 which for 5 litres is around £20 but you will get circa 15 to 20 mtrs out of a 5 litre tub with a 3 to 4 mm trowel. I have just seen on ebay 15 litre tubs of amtico's equivalent for £40 so if you are getting let's say 55 to 60 mtrs, comparing flexi addy @ an average say £12 a bag getting 6/7 sq mtr coverage would cost you circa £100/120.
The above are only a indication, and no I am not trying to flog the stuff, but it seem to financially a better bet where applicable.
The only way you get that sort of coverage is by using a v notched floor laying trowel, a 3 or 4 mm tiling trowel is unsuitable for this adhesive. I used F44 on the last couple of ply floors I did as I've always got a tub knocking around. If you haven't used it before it will seem strange how little you have to use but basically just spread the whole are you are fitting, leave for 20 mins or until it goes really tacky then fit. This adhesive will grab instantly and you won't get the membrane back up again so be careful. If you can lift it back up then you're trying to fit too early. You can walk on it as soon as you put it down and i'd recommend rolling it afterwards, I use one of these-
I have one of those rollers Pete it's the best thing I have bought, takes all the hard work out of fixing ditra/durabase.
cliff jones
rapid set flexy for me.
How do you find it with fitting with flexy? ive pulled up a few floors that have been put down with this, and generally i can just rip the sheets up with my hands in most cases, not really going anywhere fast, but then some haven't taken at all, but that could have just been down to whoever laided it originally!
Reply to Whats everyone using to stick down Ditra or durabase onto Ply subtrate in the Canada Tile Advice area at TilersForums.com
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
  • Sticky
Hi Guys What are your opinions regarding the usability between Ditra and Durabase matting? I do...
2 3
29K
Hi I am after some advice on the following, I have been to look at a job which had problems in...
8K
shick
Hi there 1st time poster - long time lurker so be gentle! I'm in a bit of a quandary and would...
10K
Qwerty
Q
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
