What's the best course of action for this wall?
Good evening all. Removed some tiles in bathroom and damaged the wall. Plaster has come off, underneath I think its bonding plaster? Haven't a clue.
What would be the best repair method for the wall, also can I installHardiebacker without plastering the wall after the repair?
Will be installing mosaic tiles.
Any help is appreciated.
Had two walls like this on Monday, also was short on space due to architraves that could not be removed.
I primed walls with TM Prime Plus, then using my tiger trowel combed TM Ultimate over walls and stuck on 6mm Delta Board and made sure they were flat with a straight edge.
Next day screwed through them using 35mm washers and screws every 200mm, tanked one side as it was in a wet area.
Sorted.
Sorted.
Will be doing this after filling a few of the deeper gouges in the damaged bonding coat with Gyproc Easi-Fill.
