When things go WRONG: Why we get called out to jobs to rescue clients with bodge job
Re: When things go WRONG: Why we get called out to jobs to rescue clients with bodge
Hi Djess you press and hold the plate in place while you drill the tile. It basically makes sure the drill tip does not skate all over the tile when drilling, very effective I must say.:thumbsup:
Its an anti-slip guide plate.
Designed to hold the drill on the wall
It replaces the need for central pilot drills which cost over £29 each and are only made of carbide metal.
All our drills are hollow diamond cores.
If you were to use a core with a pilot drill then it also needs to be fitted with an expensive arbour and water jet to continuously flood water to cool the pilot drill.
This is core with a pilot drill... WE DO NOT USE PILOT DRILLS
Removing pilot drills saves you, time, water and money.
how much does a set like that put u bk
Did'nt work mate
about 50 quid I believe, worth every penny
do u know how many holes per bit????
Depends on the tiles obviously but had my kit about 18 mths and only replaced the 8mm ones. Mainly ceramics and trav though, not much porcelain
On Porcelain tiles about 40 holes per pack (10 holes per drill bit) on the SMALL cores at 6mm and 8mm
PLUS... The drills dont just blow like a lightbulb on hole ten.
You can get more life out of them it just takes longer to drill the holes. On average about another 5 holes per drill bit is the total lifespan on HARDEST porcelain tiles taking it up to near 15
ABOUT 40 TO 60 HOLES PER PACK on the small cores.
(10 TO 15 HOLES PER DRILL)
Remember to drill slowly, use water and dont push the drills.
On Granite you can double the number of holes to about 80 per pack.
On Soft Ceramic tiles you can expect 100 holes per drill bit.
On soft ceramics 100 holes per drill bit is easily achievable simply because
there is no work for the diamond holesaw to do. Once you break the
glaze then the drill hits the powder soft clay behind and takes the hole
out in seconds. And with perfect results on Porcelain & Ceramics.
Under test conditions at:
The bigger core drills
At least twenty holes per drill at the larger sizes (more diamonds - longer life)
Bye bye Federi !
Those glass tiles in the first post:drool5::drool5::drool5: anybody know who they are by?
Deffo look the part these 365 drill bits and super highly reccommended on TF:thumbsup:
Deleted member 1779,
Dan,
Dan,
