I am currently redoing a shower cubical and was wondering whether its best to tile first then fit shower surround or fit surround then tile to it? It will be up against plaster/masonary walls. Thanks in advance
Tile first then fit screen/door etc. If you have an opening for a door ie your shower is a 3 sided wall cubicle make sure that when the tiles are on the door will fit.
Shower tray in
tile Walls
offer shower cubicle in place and drill fixing holes, remove
grout tiles
fix cubicle in place
you can drill the fixings for the shower after but if you have a tile with a deep red terracotta base it is some times easier to do it inbetween as the tile dust from drilling can stain the grout
The only point I can add to already good advice is some shower cubicles have to be fitted onto an impervious surface (ie tiles)for drainage in the frames.
Depending on which shower door you have, you will need to run a bead of Silicon down the the back of the wall channels before fixing them to the wall through your new tiles - just check that yo have ample tolerance for the door in the gap if its a door and that your walls are adequately plumb if its a quadrant shower enclosure
Thanks all, it is a quadrant eclosure so I'd better go and make sure the enclosure fits now I've recessed the tray! (plus tile thickness ofcourse!) The plumb walls might be a problem if the rest of the plastering in my house is anything to go by (its relatively new build too!)
This might be too late now but many quadrant enclosures will have some tolerance in the uprights to take into account the variations in your wall.
You will find that you fit these uprights securely against your tiles and, providing your tray is fitted correctly, the quadrant screen should lie properly on the tray.
You should (Silicon) seal the OUTSIDE of the quadrant screen against the tray. If you were to seal on the inside this can sometimes force leaks rather than prevent them.
Good luck.
