poynton phil
I tiled a 38sqm floor, L shaped room with porcelain opus pattern tiles last Aug/sept. When i went to look and measure the job, the customer told me it was going to have £32000 worth of custom built units plus a 4msq island, with granite worktops. The customer informed me that the joists will be supported with brick piers, I think the joists were spaced at 400 - 450mm. I said that the joists will need bracing every 300mm, with extra noggins, and to make sure the edges of the 25mm marine ply lay on a joist, or noggin, and screwed at 150mm centers. The whole floor was tiled, before the kitchen was fitted. I use keraquick with latex plus to fix the tiles.
I got a phone call yesterday saying that 3 tiles had airline cracks in them, and said tiles were in different parts of the room, 1 in the conservatory area, 1 up against the wall units opposite the island, and the other was a 10cm cut going under a radiator on the R/h side of the island. When i went and looked it turns out that there are 7 cracked tiles at the moment, 3 in the conservatory, and 2 in the other places, I think the island as sank, and tbh i think the whole lot will have to come out, and the customer is saying they took my advice, so its my fault. The only advice i gave was to brace the joists at 300mm, and to lay 25mm ply screwed at 150mm, along the joists, and noggins, making sure the edges of the ply are on joists or noggins. He told me about the supports they were using, and i think they haven't supported it enough. It was solid at the time of tiling.
I am absolutly cacking myself that i could be blamed for this. Any advice will be
really be appreciated.
