Discuss Why not be a Plumber .? in the UK Tiling Forum area at TilersForums.com.
Ok, i see what you mean but i need to check it twice becouse i have seen many places where plumer fix plastic instalation and these joints are always covered, in my opinion there are less safe then metal compression joints but manufactures recomment them to do water instalations anyway f.e. PEX pipes. I do not really know how compression can fail, i have never crossed with that. As I said to do simple plumber fix in bathroom you dont need lot of tools, I do it on my own and it is always success.
Compression fittings can only be used in an accessible location (because they can and do fail) and as with any mechanical joint a compression can fail, wether this is your jointing compound wearing, olive splitting, over or under compression...
I didn't feel the need to "write something" it's called "being a plumber".
And £100 - £150 for tools? I'm presuming your meaning simple things such as for connecting wastes and flexible tap connectors? My torch and pipe bender alone cost more than that!
Thanks for links you sent. I do solventing copper pipes and usually do it when i do plumber. However even if i fix plastic pipes i use metal compression (always with pipe inserts) as i see this method more safe than the regular plastic joints, in this case it is cover by partition walls etc. I am going to read all these regulation just to got wise knowladge but i still think water instaltions are easy to do and every bathroom maker should be able to do it.
Or if under tightened lol. I always nip it up first, undo the fitting to check the olive is set then some wraps of ptfe or whatever I'm using before nipping up.
ptfe on olives.????
why not jointing compound.???
I'm with you all the way on this.
But you can see why trades get bad names for themselves with the likes of others saying its easy all you need is a compression fitting and £100 tools.
Good luck to you mr Polishtradesmen.....hope you have liability insurance.
You did not understeand what i said. To do simple bathroom plumb, i dont need to hire plumber, that why my job is faster and cheaper but day rate is still high. On the beggining you need flamer (can be even for 15 pounds still is possible to solvent a joint, blanket 10 pounds, two spaners 40 pounds, pipe cutter 15 pounds) if you not sure your solventing skills use joints which got solvent inside it is so easy to do !!!! About compression, yes i use them if i think it it safe and for me it is safe esspecially if pipe sre fitted on clips and there are not moving. I see nothing wrong with compression joints below bath or for pump connection. I know thaty plastic system are recommented by menufactures to do water instalations but i use metal compression as i think it is better. What is wrong with that???? Stop writing i give trade a bad name as my job never fails!!
Reply to Why not be a Plumber .? in the UK Tiling Forum area at TilersForums.com
