White Room
ptfe on olives.????
why not jointing compound.???
I agree, used paste 40 years ago on compression fitting now they don't allow for some obscure reason...
Discuss Why not be a Plumber .? in the British & UK Tiling Forum area at TilersForums.com.
ptfe on olives.????
You did not understeand what i said. To do simple bathroom plumb, i dont need to hire plumber, that why my job is faster and cheaper but day rate is still high. On the beggining you need flamer (can be even for 15 pounds still is possible to solvent a joint, blanket 10 pounds, two spaners 40 pounds, pipe cutter 15 pounds) if you not sure your solventing skills use joints which got solvent inside it is so easy to do !!!! About compression, yes i use them if i think it it safe and for me it is safe esspecially if pipe sre fitted on clips and there are not moving. I see nothing wrong with compression joints below bath or for pump connection. I know thaty plastic system are recommented by menufactures to do water instalations but i use metal compression as i think it is better. What is wrong with that???? Stop writing i give trade a bad name as my job never fails!!
OMG you are fitting shower pumps..............................
Thanks for finally giving him a straight answer!
Reply to Why not be a Plumber .? in the British & UK Tiling Forum area at TilersForums.com
