Discuss Using SBR primer on bitumen floor to stop smell in the UK Tiling Forum area at TilersForums.com.
DHTiling
Very very thin (less than 1mm)
remove it...:thumbsup:
with one of these..
Wire Brush for Angle Grinder
A very aggressive wire brush for use in an angle grinder - You will be amazed how fast this works!
Use to remove all kinds of unwanted paint, adhesive, rust and other surface contaminants etc
Very good for 'keying' smooth surfaces.
- Hardend & twisted 0.5 mm steel strands
- 75 mm Diameter
- Standard M14 thread (fits all standard angle grinders)
- Max speed 12,500 Rpm
We recommend you wear suitable eye protection overalls and gloves while using this tool
Price: £4.49 £5.16 Including VAT at 15%
Reply to Using SBR primer on bitumen floor to stop smell in the UK Tiling Forum area at TilersForums.com
  • Question
