Discuss Using SBR primer on bitumen floor to stop smell in the UK Tiling Forum area at TilersForums.com.
Q
Qwerty
Im going to prime my solid concrete floors with SBR primer before tiling my en suite, but I also have the same crappy bitumen covering on my bedroom floor.
The tiles are up and left the residue, which is really smelly (hot tarmac!). Will a coat of SBR stop this, if not then what will please (we need to re-lay the underlay and carpet soon)
Cheers - Geoff
DHTiling
Very very thin (less than 1mm)
remove it...:thumbsup:
with one of these..
Wire Brush for Angle Grinder
A very aggressive wire brush for use in an angle grinder - You will be amazed how fast this works!
Use to remove all kinds of unwanted paint, adhesive, rust and other surface contaminants etc
Very good for 'keying' smooth surfaces.
- Hardend & twisted 0.5 mm steel strands
- 75 mm Diameter
- Standard M14 thread (fits all standard angle grinders)
- Max speed 12,500 Rpm
We recommend you wear suitable eye protection overalls and gloves while using this tool
Price: £4.49 £5.16 Including VAT at 15%
White Room
My thinking is that if your getting an odour I would get it up then prime, priming might work straight onto the bitumen but if it dos'nt your'll be taking the carpet back up when it's laid.
Reply to Using SBR primer on bitumen floor to stop smell in the UK Tiling Forum area at TilersForums.com
