Discuss Brick bond around door or window in the Canada Tile Advice area at TilersForums.com.
Dave
Subscribed
389,894
1,000,000
Co.Durham
I'm tiling my bathroom using white metro tiles 20mm x 10mm (not bevelled). I want to use a brick bond pattern. When tiling around a window/door do I start above them and work down or do I start at the first full tile above the floor and hope the pattern matches back up above the window/door.
Any advice would be appreciated. Thanks in advance.
Start at the bottom as you say. Run a vertical line up either side of the window on a tile edge and keep your bond to that. 👍
Reply to Brick bond around door or window in the Canada Tile Advice area at TilersForums.com
  • Question
Hello, after watching so many instructional videos and planing, I just can't understand how to tile a simple drywall construction in our bathroom. I got some good advice here so I hope you guys...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
  • Question
