Discuss Brick bond around door or window in the Canada Tile Advice area at TilersForums.com.
Points
36
North Tyneside
I'm tiling my bathroom using white metro tiles 20mm x 10mm (not bevelled). I want to use a brick bond pattern. When tiling around a window/door do I start above them and work down or do I start at the first full tile above the floor and hope the pattern matches back up above the window/door.
Any advice would be appreciated. Thanks in advance.
Dave
Staff member
Subscribed
Points
1,000,000
Co.Durham
Start at the bottom as you say. Run a vertical line up either side of the window on a tile edge and keep your bond to that. 👍
Points
36
North Tyneside
Thanks David,
Sounds quite obvious now you've said it but had you not i would have just tiled both sides and kept my fingers crossed that the run above the window matched.
Thanks again
Reply to Brick bond around door or window in the Canada Tile Advice area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
