Discuss DIY Tiler - 90 sq m of large format porcelaine tiling making me nervous! in the DIY Tiling Forum area at TilersForums.com.
PJPro
pj do you have a wet cutter
No. But I do have a couple of grinders.
I was thinking that maybe the plasplugs master tiler might be alright for the odd cut here and there but I was concerned that it would take to long to cut every tile with a wet saw. The dry cutter seems a much faster option....as long as I can get the tile to break where it should without chipping.
kilty55
Points
1,113
edinburgh
yes use dry cutter for straight cuts
but you need a wet cutter or a grinder with a tile cutting blade in it for angled cuts
PJPro
OK. Thanks. Am I better off with a cheap (ish) saw or just get a blade for the grinder?
kilty55
Points
1,113
edinburgh
i think you should get a wet saw pj,you may need to upgrade the blade also as a lot of the saws come with basic blades
PJPro
You say the floor 'will be' is the chip board down yet ?
Nope. But it's been bought and is on site. The Project Manager says the chipboard / hardybacker combo is the approach they usually use for their jobs.
PJPro
Could you recommend a cheap(ish) wet saw and suitable replacement blade. As I mentioned earlier, the plasplugs seems a popular choice.
guil.rocha
grinder all the way. Bosh makes good blades but make sure to go for the solid disc instead of the the ones that have splits in them.
Gazzer
Plasplugs is great if you can get one. tradetiler sell the Vitrex version. Marcrist wheels are a good replacement too.
Alan.P
Points
1,058
Stockton-on-Tees
long winded expensive way to go in my humble opinion, better off with 18 - 25mm wpb, and tile to this, with suitable preparation.
Reply to DIY Tiler - 90 sq m of large format porcelaine tiling making me nervous! in the DIY Tiling Forum area at TilersForums.com
